Group: DynoMotion Message: 13488 From: toolhoarder Date: 7/6/2016
Subject: Backlash Compensation Units?
Can someone tell me what units to use in the KMotion backlash compensation "amount" window? I can't find the information in the manual.
Right now the amount is 116.323, and the rate is 250 (z axis). I can't recall where these numbers came from. I'm using a dial indicator to calibrate the axis. It does a fine job of repeating 0.500" excursions, but I have 10 thousandths of backlash I want to get rid of.
Group: DynoMotion Message: 13489 From: Tom Kerekes Date: 7/6/2016
Subject: Re: Backlash Compensation Units?
Hi toolhoarder,
The Backlash Amount is specified in steps or counts.  See:
http://dynomotion.com/Help/Cmd.htm#BacklashAmount
So multiply your 0.010 inches by the number of counts/inch for your system.
If you are on a KMotion Screen and want to find information about a parameter - click "Help" and then click on the parameter.
Because backlash should normally be a tiny amount it usually isn't necessary to specify it to 6 digits of precision.
At a rate of only 250 counts/sec would take ~ 1/2 second to take out the backlash.  Normally about 1/10th of that amount of time should be enough.
Group: DynoMotion Message: 13503 From: toolhoarder Date: 7/7/2016
I can't even guess how I got a six-digit backlash number. Thanks for the help with the manual. Apart from a Pascal course I took in 1992, I have no programming training, so I did not understand the backlash page.
